Call forward fax number
simon.rodgers
Post by simon.rodgers »
Hi guys,
I am sure this should be in the begginers section ;)
We need to call forward two extensions to an external fax service. I created the extensions as Users and set an Immediate forward to the external fax number.
Unfortunately this does not work and all i get to hear is dead air...
I can call the external number directly and hear the fax tone. Is there a configuration entry i am missing?
OXE Rel 9.1
Simon
Re: Call forward fax number
COS/ connection COS 5 - manage 1 in pos.5.
If you have ISDN connection - check with "t3" command (show trace for this calls).
If you have analog line (external) - this is another story.
simon.rodgers
Thanks, for the reply.
I should have done more isolation before posting, i realized that it wouldn't forward to regular external numbers which led me to COS.
Also got some advice to delete the user and just create the extensions as Abbrev. Numbers which also works.
Thanks again for the assistance.
