Equivalent for show amap ?
Spack
Post by Spack »
Hi all,
On an OmniSwitch 6850, when you type show amap, you have a list of all Alcatel-Lucent equipments connected to the 6850. Of course if there is a 7750 connected, you can see it. I would like to do the same thing on a 7750 but the show amap command does not exits.
Do you know if there is a show amap equivalent on the 7750 ?
agungaryo
Re: Equivalent for show amap ?
Post by agungaryo »
CMIIW ,
I don't ever heard "amap" is supported by TiMOS
i guess it caused amap is used for interswitch protocol, n get advantages from spanning tree enabled . . while 7750 is a router
Return to “7750 SR”
