Voice Mail 4645 with 2 Appliance server
thanzeel
Post by thanzeel »
Hi all,
I'm having in a site 2 appliance servers. and one of them is embedded with voicemail 4645. How do I know which one of the Appliance server is with Voicemail 4645? or can I use any one of them? How do I configure the voice mail in such a case?
Please help me out in this situation. Its of very critical situation
Thanks and Regards
Thanzeel Shajahan
thanzeel
Re: Voice Mail 4645 with 2 Appliance server
Post by thanzeel »
In addition to the previous mail, It is a redundant system with the appliance servers
thanzeel
Post by thanzeel »
hi can anyone please respond
Applications/ voice mail - you have item - Voice Mail CPU Name - this is name of your AS.
thanzeel
Post by thanzeel »
Thanx.... I'll be putting the IP address of local PC..... So during bascul will the voice mail work?
tailtwist
Post by tailtwist »
If you have set CPUa as your CS+4645...when it goes for a reboot the 4645 will not be accessible until it comes up again either as a standby/main
if you need 4645 to be 'always accessible' then your 4645 VM should sit on another board(CS-1/CS-2 or appliance)
schumi
Post by schumi »
I have the following setup: 1 cabinet holds the primary CS-2 call server and the CS-2 4645 voice mail. The second cabinet holds the standby CS-2 call server. I understand the voicemail is available to both main and standby, it only reboots between switches.
It is correct to assume that this is not a redundant voice mail system ? If the first cabinet looses power there will be no voicemail CS-2 to access.
My question is how can I get a redundant voicemail system? Do I need to install a secondary CS-2 with voice mail or the call server CS/2 should be installed as a mixed CS/voicemail ? Or is it another option ? Thank you!
tgn
Post by tgn »
not with 4645... the bittersweet ALE answer is opentouch.
regards...
--- back to basics... focus your eyes on the essential things... ---
Return to “Voicemail (46x5)”
