In need of the Incidents Meaning
If you wrote a good one, share it with us !
wallacezammit
Post by wallacezammit »
I would like to find a list of the Incidents (Alarms) of the OXE together with their meaning.
Some of them i find them on alcatel site but others are not found, or found with very basic description.
Does anyone know from where i can find this list?
Thanks and Regards
Wallace
Re: In need of the Incidents Meaning
Use command "incinfo" if you want to see incident meaning but very often this is very basic description.
Or may be use help like this.
wallacezammit
Thanks for your info!!
Regards!!
zetor2000
Post by zetor2000 »
Do You have same information/description in connection to 10.x?
zetor2000 wrote:Do You have same information/description in connection to 10.x?
Do you have problem with incidents not exist in "R9.0_incidents"?
alurfe
Post by alurfe »
Incidents_R10.0
Return to “Documentation”
