Incident 1542
mgsox
Incident 1542
Post by mgsox »
i have the incident 1542=Partition 6 is 78 per cent full (resource 1). on an OXE R9.0.
does any one know what do i have to do solve the problem? do i have to replace the HDD?
thanks for your support
ranlp
Re: Incident 1542
Post by ranlp »
Check the free/used space on the partitions (df -h).
mysticalself
Re: Incident 1542
Post by mysticalself »
Do the following for the resolution.
1.cd /DHS3dyn/incid
2.mv logrotate.status logrotate.status.old
3.cd /var/spool/mqueue
4.for i in *; do rm -f $i;echo deleted $i;done
5. /usr/sbin/logrotate -s /DHS3dyn/incid/logrotate.status /DHS3data/incid/logrotate.conf -----> configure the file with the new date.
Check TC 1289 for details.
Eliott
Re: Incident 1542
Post by Eliott »
Check with top command the memory usage of sipmotor process. There is the problem I guess.
EDIT: The logrotate posting is correct. I mixed up the incident 1542 with 2071=Swap partition xx per cent full. My mistake...
mgsox
Re: Incident 1542
Post by mgsox »
mysticalself wrote:Do the following for the resolution.
1.cd /DHS3dyn/incid
i will check. thanks very much for your help
Return to “GENERAL”
