Change VLAN using SNMP
hinesh
Post by hinesh »
Hi to all forum members.
As I understand, to put an interface into a VLAN the correct CLI command is as follows
In this case as a mere example the vlan is 212 and the interface / port is 1/17
Vlan 212 port default 1/17
Now if I wanted to achieve the same using SNMPSET, could a forum member show me how this can be done as in which MIB \ OID's to use and what the
SNMPSET command would look like
Regards Hinesh
