BiCS Upgrade
BiCS Upgrade
Hi guys,
one question about this, when you want to do an upgrade on BiCS, is it mandatory to have an external USB HD? Can't you use your laptop for this?
Schpice
Re: BiCS Upgrade
Post by Schpice »
It's not mandatory to use an external USB HD, but it's better because you can save all your virtual machines before upgrade Bics and if you have problems during upgrade you can reload old virtual machines.
But I dont know if you can use a laptop as backup space, I think it's not possible unless you can use the laptop in NFS Server but without prejudice.
Re: BiCS Upgrade
Ah...ok got the idea. Thanks!
Eliott
Re: BiCS Upgrade
Post by Eliott »
In newer BiCS versions you are allowed to save the data to network file systems (NFS), too. But if you are coming from 1.x 2.0.x it works with USB only.
Re: BiCS Upgrade
Nice, thanks Eliott! :)
Return to “MAIN”
