problem with mastercopy
youfo007
Post by youfo007 »
hello
CPU3 my version of R2.1 fails, I have another alternative that contains CPU3 in another configuration for another site.
As soon as I run the command in swinst to stop the phone on standby, he launched a shutdown of the standby. When I run the command MasterCopy twincpu a message to choose between two options:
1 Use C1 link
2 Use Ethernet
I work on a terminal connected to the CPU on V24 so I chose Option 1: Use C1 link.
Here I am stuck with a message that appears saying "ERROR YOUR ROLE MUST BE STAND-BY "
thanks
Re: problem with mastercopy
First CPU - in "main" state, telephone application started.
Second CPU - telephone application not started (unset autostart before shutdown or interrupt start DHS3 in V24 port).
Mastercopy must be started on second CPU.
youfo007
Post by youfo007 »
the host name is on stand-by a4400a, now the name of the main is also a4400a.
Is it logical?
When you use cloning operation - you can clone Chorus (Linux data) or database.
If you want to make duplicate system:
- manage in netadmin (new cpu) main parameters (IP for this CPU and twin - "main");
- netadmin -m (new cpu) - copy setup/ copy from twin CPU.
mastercopy - clone database.
youfo007
Post by youfo007 »
please, is that you can explain to me these last stages of advantage.
" - manage in netadmin (new cpu) main parameters (IP for this CPU and twin - "main");
mastercopy - clone database. "
thanks
When I want to change CPU:
- for new CPU manage IP address (own and twin);
- for another IP parameters (hosts name, routing...) - netadmin -m / copy setup/ copy from twin CPU (load netadmin parameters from main CPU).
- for database cloning I prefer - swinst/ expert menu/ cloning&duplicate/ CPU cloning/ cloning database.
If after mastercopy you have both CPU with the same name - I think you choose "cloning Chorus data"
Turlupin
Post by Turlupin »
If you're on the stand by cpu, you can run a mastercopy while the Telephone application is started using the C1 Link.
Turlupin
Sorry for my english .... :)
Return to “Swinst”
