Trace a Trunk Group
alcaman
Trace a Trunk Group
Post by alcaman »
Hello I am alcaman and I´m a Newbie in this forum.
But i have a problem and i need your help.
I will trace the traffic on a trunk group with 60 Channels, 2xPra Boards.
Some calls dropped and my customer need this information.
Which is the best way to do that, t3 or mtracer?
thx!
Re: Trace a Trunk Group
t3 - just script for starting mtracer with some parameters.
For usual check - more simple to use the t3 command.
With mtracer - you can use some additional options (f.e. check for unique calling number).
In system doc - public network/ ISDN - you can find "maintenance" chapter with description "how to start and end trace"
alcaman
Post by alcaman »
thx vad !
i read the chapter "how to start and end trace"
Return to “Traces”
