user profile configuration
jorge veiga
i need to create a new user on 4760 R5.1 so that he can only configure his users in the configuration module this user belongs to a diferent entity and i wnat him to be able to change only certain configuration
- tot3nkopf
Re: user profile configuration
I think this can only be achieved using Omnivista MCS, not NMS. Any other ideas gents?
It is possible with 4760 NMC-tot3nkopf wrote:. Any other ideas gents?
Just use "Identifier of Domain" parameter on users and check "Security" part (Section 12) in 4760 Admin docs. It is written there how to create users and configure certain access for certain groups.
┌─Help: Identifier of Domain─────────────────────────────────────────────────┐ │ │ │ Press CANCEL to remove this window │ │ │ │ Enter an integer value │ │ within the following ranges: │ │ 0 to 254 │ │ │ │ Identifier of Domain │ │ This attribute defines the domain that the user belongs to. │ │ Domains can only be used from NMC management systems. │ │ They are used to distinguish between departments or companies installed on │ │ the same 4400. Each manager can only access users corresponding to his │ │ domain (see the object ACCESS CONTROL). │ │ │ └────────────────────────────────────────────────────────────────────────────┘
jorge veiga
Thanks for your help guys , will try this and give u an answer , cheers
jorge veiga
hi guys, have tried to configure my user but cannot get the user to see only his extensions when he is in configuration in the 4760 , have tried to follow the steps mentioned in the docs
