Any one can breifly explain that "Why all the telecom equipments using -48dc volts?"
here..some reason
1.To prevent wire corrosion
2.due to the telephones sets
3.world wide Telephone operating volts-48
4.??????????
-48 volts
Re: -48 volts
Why all?
In many places (especially for old equipment) used "-60V".
For mobile equipment or small PBX (with short line) used "-24V".
letacla.alcatel
Re: -48 volts
In general case.... mostly PBX operating volts -48..why..? is there any reason..?
Alcatel,OTN's, Mux's, Nortel, Siemens, Erricson...and so on.....
- Konstantinos.E
Re: -48 volts
hi
i think is because of the electronic equipment.maybe most of electronic parts for pbx's works more efficient under this voltage.
Alca_holic
letacla.alcatel
Re: -48 volts
hi
I know DC works more efficient......The Question is why -48V
{|48v|}....???????{|-_-|}........!!!!
Re: -48 volts
I think - for battery (from chemical point) was chosed 12V.
After, different system (with battery backup power) use 12, 24, 36, 48, 60 V power sources.
12 auto, very small PBX (Alcatel 4200 f.e. - 12 V for digital set and 48 for analog).
24 some auto, small PBX (Panasonic)
48 many telecom equipment.
64 old telecom equipment.
- Konstantinos.E
