Documentation on changing the existing CF card
francky
Post by francky »
I have a 6850 which is not booting and I would like to change the existing CF card (as it has information which need to be cleared): I think I would like to switch the existing CF card with another one having the AOS, but no configuration, in order to return it for service.
I have not found information on accessing or replacing the CF card in the Hardware Manual.
Is there a document giving the procedure ?
Francky
cedric1
Re: Documentation on changing the existing CF card
Post by cedric1 »
hello
No documents, only internal to ALU procedure.
Cedric
