RightFax whit OXO
Guillermo
RightFax whit OXO
Post by Guillermo »
I have a problem with a RightFax server and an OXO, the server doesn't detect the digits sent by the OXO.
Has somebody associated a RightFax server with an OXO? what configuration is it necessary to keep in mind?
Thank you
Guillermo
henk1964
Post by henk1964 »
OXO is to fast on sending digits.
There is a timer for off hook detection on analog ports.
Increase the timer to a much higher value and it should work better.
Did have the same problem with dialogic boards on OXO and it worked for me. If you want i can look in the backup to see wich timer was changed.
Guillermo
Post by Guillermo »
thank you for your answer.
Do you remember that timer had changed? And that value has placed?
Thank you
Guillermo
henk1964
Post by henk1964 »
Can not find the backup :-(
It was a timer with something like off hook in it but will dust of the old laptop and see if i forgot to transfer some backups..
Get back to you on this.
Return to “MAIN”
