Duration Accounting Cost calculation
sera544
Post by sera544 »
Hi All,
OXE R.5.1 Hotel interface with fidelio, client is asking a change for international calls, first 60 sec 1$ second 61 to 120 sec 3$ and so on, in duration accounting i have the charge scale number 8 belong to international calls.
I try to modify and achieve this i couldn't come up with result,
Charge scale 8
First stage Hours 24 and minutes 0
Tarif 1
stage 1 charge unit - 1 and duration 60 sec
stage 2 charge unit - 3 and duration 120sec...this is my configuration in oxe but after i make call more than 60 sec it shows 2$ instaed of 3 $, is there any way we can achieve this scenario or may am doing some mistake can u plz advise me..
thanks in advance..
ACSE Business R.9.x
Re: Duration Accounting Cost calculation
Tarif 1
duration 60 - unit 1 --> Each 60 sec=1 unit.
if you want
1st 60 sec=1
2nd 60 sec=3
all another 60 sec=5 (f.e.)
You need to manage
1st stage =60 sec
2nd stage =60 (or 2 min, not sure)
Tarif 1
1st stage duration 60, unit 1
2nd stage duration 60, unit 3
3d stage duration 60, unit 5.
sera544
Post by sera544 »
Hi Vad,
Thanks for your reply, its working VAD...my mistake was in 1st stage i have given 24 hrs 0 min after i change to 0hrs and 1 min for stage 1 and stage 2 it started working properly the way we expected..thanx a lot ...
cheers,
Pandian
ACSE Business R.9.x
Return to “Hotel / Hospital”
