SIP component failure
thkim81
Post by thkim81 »
Hi~
I testing with genesys 8.0
but Genesys guy said " Network access error....."
then I checked my oxe log. I saw below logs.
16/06/11 21:11:06 000001M|---/--/-/---|=0:5812=SIP external gateway 1 is in service
16/06/11 21:15:48 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:16:12 000001M|---/--/-/---|=0:5813=SIP external gateway 0 is out of service
16/06/11 21:16:12 000001M|---/--/-/---|=0:5813=SIP external gateway 1 is out of service
16/06/11 21:16:12 000001M|000/00/-/---|=3:5801=30 SIP trunk group put out of service
16/06/11 21:16:16 000001M|000/00/-/---|=5:5800=30 SIP trunk group put into service
16/06/11 21:16:16 000001M|---/--/-/---|=0:5812=SIP external gateway 0 is in service
16/06/11 21:16:16 000001M|---/--/-/---|=0:5812=SIP external gateway 1 is in service
16/06/11 21:16:40 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:22:10 000001M|---/--/-/---|=4:4017=CSTA server : new creation 3 10.129.48.151
16/06/11 21:22:17 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:23:05 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:25:54 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:26:34 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:27:41 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:28:30 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:29:49 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:34:37 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:34:40 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:36:21 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:37:28 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
16/06/11 21:38:34 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
Why does take 5816 log ?
I wonder this log.
PS :
I attaching the log file.
Return to “SIP”
