4635 - All Main Menu Options not included in the prompt
siti
Post by siti »
I want the voice prompt to read out all the options in the main menu.
At the moment it is giving 2 options only; "to send a message,press 2" and "to disconnect,press * ".
When I dial 4 for personal options,it worked. But my customer wants the guide to tell them all instead of the two options only.
Can someone tell me how this can be done?
Cheers
There is no lift to success.You have to take the stairs - one at a time.
Isa
Post by Isa »
You will need to connect directly to the Voicemail VPS 4635 adapter with the V24 cable, in order to access the 4635 configuration options.
You have to use the special Alcatel cable V24, which comes with an special connector to plug it on the rear connector of the VPS35 and a serial connector to plug on the notebook or desktop PC. Then you access the system using Hyperterminal
Com1
9600 8 1 n
Emulation autodetect
The default initial password is Password 5555 or can be 2222
I've got the VPS35 manual which describe the menus of the voicemail system configuration if you need.
siti
Post by siti »
Thanx for the reply Isa.
I was referring to the main menu that the voice guide plays when callers dial in to the voicemail system to check their messages.
In the management menu,I dont have any problems as I can access it thru the way you had just mentioned.
My apologies for not clarifying the issue in my intial posting.
Siti
siti
All Main Menu Options not included in the prompt - Solved
Post by siti »
Solution – this will be done from the individual mailbox.
The prompt level can be “standardâ€
fuldfart
Re:
Post by fuldfart »
Where do you plug in the cable in the VPS35 card ?
I also have a cable for ethernet connection, where do I put that ?
Best regards
John Andersen
Denmark
Isa wrote:Hi
Com1
9600 8 1 n
Return to “Voicemail (46x5)”
