Call Trace
ybelal
Call Trace
Post by ybelal »
Anyone here will please tell me the step by step procedures to trace calls from and into a telephone extensions (equipment).
ybelal
Post by ybelal »
t3 call trace for an equipment (extension) procedures/commands or steps.please.
sadim
Post by sadim »
use:
mtracer -a mcdu
Sadim
Eliott_DUP
Post by Eliott_DUP »
trcterm d <mcdu> :twisted:
trcterm stop (to stop)
ybelal
Post by ybelal »
mtracer says that it is activated and trcterm also show almost the same information.In fact what i want is that i want to see any input/output (I/O) bit by bit , i mean since hand set onhooked to off hooked, want to see what is happinging in real time in the mtcl screen. May be i couldn't explain well but hope people will understand by their own intelligent what i am trying to mean.
Eliott_DUP
Try "tuner km" or "killall mtracer" command before.
You can also try:
tuner km
eqstat d <mcdu>
tuner ctr
tuner +cpl +cpu
actdbg all=off
trc i
trc C <crystal> c <coupler> t <terminal> (read from eqstat)
tuner +at,<neqt> (read from eqstat)
actdbg <your_filter_choice>=on  (if needed)
mtracer -aAuUd -1 /tmpd/trcfile -f 10 -s 10000000
tail -f /tmpd/trcfile-00
Sample output:
(709801:000003) 1202: Send_IO1 ( 2 )
(709801:000003) Dump: .00.00.50.00.00.0f.02.02.08.00.a1
(709801:000003) Dump: .04.00.47.01.23.23.02.00.3f.00.03.00.21.03.03.03.00.21.03.07
(709801:000003) Dump: .09.00.49.02.02.03.05.08.0d.16.25.03.00.21.03.03.03.00.21.03
(709801:000004) Dump: .07.03.00.21.00.02.03.00.29.04.04.10.00.27.00.00.42.69.74.74
(709801:000004) Dump: .65.20.77.84.68.6c.65.6e.3a
 _________________________________________ UA Message ________________________
( (709801:000003) 1202: Send_IO1 ( 2 )
( lg : 80 dest : 0 src : 15 cr : 2 cpl : 2 term : 0 type a1
(        <<<<  message send :              UA_SEND (a1)
(_____________________________________________________________________________
( OP:[47] ICON COMMAND (l=4) Icon 01 : 23 23
( OP:[3f] MUTE (l=2) : 00
( OP:[21] LED CONTROL (l=3) : Led Number 3  RED LED SLOW FLASH
( OP:[21] LED CONTROL (l=3) : Led Number 7  RED LED SLOW FLASH
( OP:[49] DPI CONFIGURATION (l=9) : 02 02 03 05 08 0d 16 25
( OP:[21] LED CONTROL (l=3) : Led Number 2  LED OFF
( OP:[29] SELECT VOICE MODE (l=3) : VOICE MODE HANDS FREE
(            Speaker Volume: 4
( OP:[27] LCD LINE 1 (l=16)
(         CLEAR LINE & WRITE FROM COLUMN 00: 'Bitte wählen:'
Return to “System”
