Hello
When I try to save the BOF (bof save) a message "primary image sync failed" is shown.
What is the problem? Can anybody help me?
TX in anvance!
Primary image sync failed
agungaryo
Re: Primary image sync failed
please check :
- show card
- file dir cf3-b:\
- file dir cf3-a:\
- show bof
- show card
- file dir cf3-b:\
- file dir cf3-a:\
- show bof
lukyg83
A:AP013_FCP70_SAR8# admin save
Writing configuration to cf3:\AP013_FCP70.cfg
Saving configuration ... OK
MINOR: CLI Standby CPM is offline.
A:AP013_FCP70_SAR8# bof
A:AP013_FCP70_SAR8>bof# save
Writing BOF to cf3:/bof.cfg ... OK
Syncing boot environment:
boot option file : cf3:\bof.cfg
MINOR: CLI Boot environment sync failed - BOF sync failed; Failed to get compact flash information.
A:AP013_FCP70_SAR8>bof# exit
A:AP013_FCP70_SAR8# show card
Card State
Slot/ Provisioned Equipped Admin Operational Num Num Comments
Id Type Type State State Ports MDA
1 iom-sar iom-sar up up 6
1/1 a16-chds1 a16-chds1 up up 16
1/5 a8-ethv2 a8-ethv2 up up 8
1/6 a8-ethv2 a8-ethv2 up up 8
A csm-1g csm-1g up up Active
B csm-1g up down Standby
A:AP013_FCP70_SAR8# file
A:AP013_FCP70_SAR8>file cf3:\ # dir
Volume in drive cf3 on slot A has no label.
Volume in drive cf3 on slot A is formatted as FAT32.
Directory of cf3:\
01/01/2000 12:00a 4115 bootlog.txt
01/03/2000 04:31p 2709 AP013_FCP70_SAR8.ndx
01/02/2000 04:30p 11147 AP013_FCP70_SAR8.cfg.1
01/03/2000 04:31p 11147 AP013_FCP70_SAR8.cfg
01/04/2000 01:51a 541 bof.cfg.1
01/04/2000 01:52a 541 bof.cfg
07/20/2011 04:48p <DIR> 7705-TiMOS-3.0.R1
01/03/2000 12:17a <DIR> LOG
07/20/2011 04:48p <DIR> SUPPORT
06/16/2011 11:35a 208 bof.cfg.bak
02/06/2000 12:27a 1896896 boot.ldr
02/09/2000 08:22a 2682 AP013_FCP70_SAR8.ndx.5
01/01/2000 12:00a 2373 bootlog_prev.txt
07/11/2010 05:38p 46894651 BOTH.TIM
07/11/2010 05:38p 7079 MD5SUMS.TXT
01/02/2000 04:30p 2709 AP013_FCP70_SAR8.ndx.1
01/01/2000 04:31p 11147 AP013_FCP70_SAR8.cfg.2
01/01/2000 04:31p 2709 AP013_FCP70_SAR8.ndx.2
02/10/2000 08:21a 10848 AP013_FCP70_SAR8.cfg.3
02/10/2000 08:21a 2682 AP013_FCP70_SAR8.ndx.3
02/09/2000 11:06p 10848 AP013_FCP70_SAR8.cfg.4
02/09/2000 11:06p 2682 AP013_FCP70_SAR8.ndx.4
02/09/2000 08:22a 10673 AP013_FCP70_SAR8.cfg.5
01/04/2000 01:52a 2709 AP013_FCP70.ndx
02/06/2000 12:27a <DIR> TiMOS-B-3.0.R3
02/06/2000 12:25a <DIR> TiMOS-B-4.0.R2
02/06/2000 12:27a 527 bof.cfg.2
01/04/2000 01:51a 2709 AP013_FCP70.ndx.1
01/04/2000 01:52a 11195 AP013_FCP70.cfg
01/04/2000 01:51a 11195 AP013_FCP70.cfg.1
07/20/2011 04:49p 211 bof.cfg.3
26 File(s) 48916933 bytes.
5 Dir(s) 113205248 bytes free.
A:AP013_FCP70_SAR8>file cf3:\ # cd cf3-b:
MINOR: CLI Could not connect to FTP URL xxx.xxx.xxx.xxx
MINOR: CLI The system cannot find the path specified.
A:AP013_FCP70_SAR8>file cf3:\ # exit all
A:AP013_FCP70_SAR8# file dir cf3-b:
A:AP013_FCP70_SAR8# show bof
BOF (Memory)
primary-image cf3:\TiMOS-B-4.0.R2\
primary-config cf3:\AP013_FCP70.cfg
secondary-image cf3:\7705-TiMOS-3.0.R1
autonegotiate
duplex full
speed 100
wait 3
persist on
console-speed 115200
Card State
Directory of cf3:\
BOF (Memory)
autonegotiate
duplex full
speed 100
wait 3
persist on
agungaryo
B csm-1g ....... up down Standby
it's clear enough that CSM not equipped . . .
it may be caused by
1. still unplugged CSM B card ( caused HW failed or the CSM unplugged yet)
2 failed Boot ,because failed to sync with CSM A
but I suspect the first one, because the card is totally undetected
or you just put a single CSM into chassis
it may be caused by
