Port Security Problem
kpltyong
Post by kpltyong »
Hi All,
Have any command can auto convert mac address to static?
Example:
port-security 1/1-6 enable
port-security 1/1-6 maximum 1
port-security shutdown 1 convert-to-static enable
port-security 1/1-6 max-filtering 1
After timer expire, it have convert mac address to static from port 1 to port 5. After one week, i plug in to port 6 but it cant working. So, have any command to do auto convert mac address to static after timer expire? is it possible?
Thanks for your help
cedric1
Re: Port Security Problem
Post by cedric1 »
hello
Did you connect on port 6 the same pc one week before as one week after
can you make a show port-security
did your mac always been learned as static on port 1/6
Cedric
