I'm new with OmniPCX. I want to enable ssh so I use netadmin -m and select option 11, "Security".
In the instructions is writted that here there is an option to configure ssh, option 7 "ssh configuration", but I haven't this option.
Any suggestion?
Thanks.
Enabling SSH
Enabling SSH
Witch is the release ?
As far i can remember ssh feature starts in R6.0
eng yazan86
Re: Enabling SSH
hello there ,
in order to activate the (SSH) on your system you have to login as supervisor
login to mtcl account
then write : su
password : letacla
then write netadmin -m
choose security (11)
ssh configuration (7)
and type yes to enable the ssh on your system .
i hope that will work with you .
best regards .
then write : su
password : letacla
best regards .
Re: Enabling SSH
Ermm thanks but this post is from 2007...About 9 years ago. please don't bring back old posts
eng yazan86
Re: Enabling SSH
i know that but i thought it would be useful to any one who might face this problem .
