4039 Set from S0 Adapter problem
andruvius
Post by andruvius »
I had to use a S0 adapter to add an ISDN phone to our OXE system. I had no issues getting this to work. However the documentation (with diagram) also indicates that you can connect an optional 4039 set to the S0 adapter as well. The 4039 powers up fine but will only display the firmware revision number. I looked up and down through the docs but can't find any reference on what to configure for the optional 4039 set to work. :?
Re: 4039 Set from S0 Adapter problem
S0 adapter - declare adapter in shelf/board/TA adapter, create S0 baus, create S0 set (you need to move jumper inside the box from the default position).
S0 adapter+4039 - declare 4039 set, in user parameters check item "S0 extension", create S0 bus, create S0 set (not move jumper inside the box from the default position).
