Having 2 OXE R7.1 connected via Hybrid Link and VPN Overflow with a IP-Trunk. When I dial an extention from Node 1 to Node 2 i got this Message on the display of the MIPT:
Assert:rtp_skt.c
LN 1022
I'm using no compresson.
Dialing in Node 1 works
MIPT: Not able to dial an Ext. over IP-Trunk
mozi
now it works. I had to change the IP-Compression of the Inter Node Link :
from default to G711
+-Review/Modify: VPN Overflow------------------------+
¦ Node Number (reserved) : 101 ¦
¦ Instance (reserved) : 1 ¦
¦ Node X - Node Y : 1-2 ¦
¦ Network 1 : 14 ¦
¦ Network 2 : 14 ¦
¦ VPN Hop cost : 1 ¦
¦ Mandatory VPN hop in quality 0 + True ¦
¦ Mandatory VPN hop in quality 1 + True ¦
--------> IP Compression Type + G 711 ¦
¦ Use of volume in system + YES ¦
¦ Maximum number of IP calls : -1 ¦
¦ Maximum number of other calls : -1 ¦
¦ Network 1 : 14 ¦
¦ Network 2 : 14 ¦
