We have an oxe R7.1. We've changed its hdd and load the backup and ops files. SIP was working with the same config before we do that. But now sip between oxe and oxo is not working. We got the trace below when we tried to call from oxo to oxe.
traced started ...
1319269404 -> main.trace.timer = 480mn
1319269438 -> [info : CTransport::setConnectionEntry(192.168.104.246,49151,0)]
1319269438 -> [info : CTransport::setConnectionEntry(192.168.104.246,49151,0)] new entry
1319269438 -> info : CTransport::receiveUdpProc() from 192.168.104.246:49151 prot:0 rc:768 msg:16 new
1319269438 -> [info : CTransport::setConnection()] 2 create timer handler
1319269438 -> [info : CTransport::setConnection()] m_iNbConnection < m_iNbConnectionMax [3 < 1014]
1319269438 -> RECEIVE MESSAGE FROM NETWORK (192.168.104.246:49151 [UDP])
INVITE sip:2005@192.168.15.246 SIP/2.0
Supported: 100rel
User-Agent: OxO GW
P-Asserted-Identity: "Bilgisayar Oprt" <sip:111@192.168.104.246>
To: sip:2005@192.168.15.246
From: "Bilgisayar Oprt" <sip:111@192.168.104.246>;tag=48913e83c59761eacf82a1a1b6c38573
Contact: "Bilgisayar Oprt" <sip:111@192.168.104.246>
Content-Type: application/sdp
Call-ID: af61c15f5e934e921d4a9da57881c354@192.168.104.246
CSeq: 1016698335 INVITE
Via: SIP/2.0/udp 192.168.104.246;branch=z9hG4bKb1bacbf52f33f8cef1b729b9c6385c90
Max-Forwards: 70
Content-Length: 215
v=0
o=default 1319269250 1319269250 IN IP4 192.168.104.246
s=-
c=IN IP4 192.168.104.246
t=0 0
m=audio 32082 RTP/AVP 18 4 8 0 106
a=sendrecv
a=maxptime:120
a=rtpmap:106 telephone-event/8000
a=fmtp:106 0-15
1319269439 -> 10 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
1319269439 -> [CIOCom::receiveRequest] Received CRequest 10 ref=1
1319269439 -> [CDispatcher::onIncomingRequest()]
1319269439 -> [CDispatcher::processRequestFromManagerIndex()] start at index 0
1319269439 -> 102 [CCallManager::onIncomingRequest()]
1319269439 -> [CMotorCallManager::callFactory] For call : af61c15f5e934e921d4a9da57881c354@192.168.104.246.
1319269439 -> [CMotorCall :: CMotorCall()]. Start!
1319269439 -> [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmiPCX Enterprise R7.1 f5.401.36
1319269439 -> 1113 [CCall::receiveRequest] INVITE
1319269439 -> 1113 [CCall::getDialog] Confirmed Dialog is not found (ID = ;48913e83c59761eacf82a1a1b6c38573)
1319269439 -> 1113 [CCall::getDialog] Returning Initial Dialog Server
1319269439 -> 1513 [CDialog::receiveRequest]
1319269439 -> 1513 [CDialog::receiveInviteRequest]
1319269439 -> 2113 [CTransaction::changeState] STATE CHANGED TO INITIAL
1319269439 -> 2113 [CTransaction::changeState] notifying the parent dialog
1319269439 -> 1513 [CDialog::onTransactionState(pTrans = 2113, previousState = Terminated, currentState = Initial, reason = None]
1319269439 -> 2113 [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
1319269439 -> 2113 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1319269439 -> 1513 [CDialog::onTransactionState(pTrans = 2113, previousState = Initial, currentState = Proceeding, reason = Request reception]
1319269439 -> 2113 [CTransProceedingState::createResponse] CResponse D ref=1
1319269439 -> D [CMessage::send] sip_sendMessage (192.168.104.246:5060)
1319269439 -> SEND MESSAGE TO NETWORK (192.168.104.246:5060 [UDP]) (BUFF LEN = 323)
SIP/2.0 100 Trying
Content-Length: 0
1319269439 -> info : CTransport::createConnectionUdp 192.168.104.246 5060
1319269439 -> [info : CTransport::setConnectionEntry(192.168.104.246,5060,0)]
1319269439 -> [info : CTransport::setConnectionEntry(192.168.104.246,5060,0)] new entry
1319269439 -> CSipUdpTransport::setChannelOptions()
1319269439 -> [info : CTransport::setConnection()] 3 create timer handler
1319269439 -> [info : CTransport::setConnection()] m_iNbConnection < m_iNbConnectionMax [4 < 1014]
1319269439 -> 1513 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
1319269440 -> [---*--- SESSION-TIMER ---*---] New CSessionTimerContext from request (Server, UA)
1319269440 -> [---*--- SESSION-TIMER ---*---] Update CSessionTimerContext (refresh reception)
1319269440 -> 1113 [CCall::checkAuthentication] INVITE
1319269440 -> 1113 [CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
1319269440 -> [CGwMngData::isAuthenticationRequiredForThisClient] 192.168.104.246 .
1319269440 -> [isDomainFromGwExt] Host from request is : 192.168.104.246.
1319269440 -> domain from External Gateway 3.
1319269440 -> [isUserRegistred] getRegistration=2005.
1319269440 -> [isUserRegistred] result=-1.
1319269440 -> [CMotorCall::onReceiveRequest] request for gateway.
1319269440 -> [CMotorCall::onReceiveRequest] state = INITIAL_STATE.
1319269440 -> [onReceiveRequest] nb available licenses=8 .
1319269440 -> [CMotorCall] presumed to be the same Dialog
1319269440 -> [onReceiveRequest] Invite => update the inviteContext.
1319269440 -> [CForkedBranch::CForkedBranch] context = 0xbffff2f8.
1319269440 -> [onReceiveRequest] CAC = 0
1319269440 -> [receiveInviteMessage] Call: af61c15f5e934e921d4a9da57881c354@192.168.104.246 eqt: -1 INITIAL_STATE received a message.
1319269440 -> [isValidGwExt] ext gw 3 is valid
1319269440 -> [checkSdpValidity] Sdp contains 1 media description(s).
1319269444 -> [checkSdpValidity] Media 0 type 1 contains 5 formats.
1319269444 -> [checkSdpValidity] Format : 18.
1319269444 -> [convertSdpIntoTsdp] Sdp contains 1 media description(s).
1319269444 -> [convertSdpIntoTsdp] The audio media contains 5 format(s).
1319269444 -> [convertSdpIntoTsdp] Format 0 is 18.
1319269444 -> [convertSdpIntoTsdp] Format 1 is 4.
1319269444 -> [convertSdpIntoTsdp] Format 2 is 8.
1319269444 -> [convertSdpIntoTsdp] Format 3 is 0.
1319269444 -> [convertSdpIntoTsdp] Format 4 is 106.
1319269444 -> [convertSdpIntoTsdp] Get the direction.
1319269444 -> [convertSdpIntoTsdp] Direction is sendrecv.
1319269444 -> [convertSdpIntoTsdp] The connection is at session level.
1319269444 -> [convertSdpIntoTsdp] Connection address retrieved in sdp: 192.168.104.246.
1319269444 -> [convertIPStrIntoTuipv] 192.168.104.246 => 192.168.104.246
1319269444 -> [receiveInviteMessage] ReferBy = Zero indirect=1
1319269444 -> [emitEventToMonitel] content size (lginfo): 648
1319269444 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 1613 inserted.
1319269444 -> [emitEventToMonitel] Event sent on eqt : 1613
1319269444 -> [display_ipc_out] ------------ Begin ---------------
1319269444 -> INVITE
1319269444 -> REQUEST URI : 2005@192.168.15.246:5060 ; user=name
1319269444 -> FROM : <Bilgisayar Oprt> 111@192.168.104.246:5060
1319269444 -> TO : <> 2005@192.168.15.246:5060
1319269444 -> CAC : 0
1319269444 -> CAC ADDRESS :
1319269444 -> CLIR : 0
1319269444 -> SDP :
1319269444 -> ADDRESS : 192.168.104.246 :32082
1319269444 -> ALGOS :
1319269444 -> G729
1319269444 -> G723
1319269444 -> PCMA
22/10/11 10:44:00 000001M|--/--/-/---|=0:1721=Phone exc 14, PC 0x085a2cc6 neqt 1613
1319269444 -> PCMU
1319269444 -> 106
1319269444 -> DIRECTION : SEND & RECEIVE
1319269444 -> N_GW_EXT : 3
1319269444 -> [display_ipc_out] ------------- End ----------------
1319269444 -> [info : CTransport::setConnectionEntry(192.168.104.246,49151,0)]
1319269444 -> info : CTransport::receiveUdpProc() from 192.168.104.246:49151 prot:0 rc:768 msg:1
1319269444 -> info : CTransport::DoSTest(192.168.104.246,49151,0) NbMsg:1 < seuil
1319269444 -> RECEIVE MESSAGE FROM NETWORK (192.168.104.246:49151 [UDP])
Supported: 100rel
User-Agent: OxO GW
Max-Forwards: 70
Content-Length: 215
v=0
s=-
t=0 0
a=sendrecv
a=maxptime:120
a=fmtp:106 0-15
1319269444 -> 11 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
1319269444 -> [CIOCom::receiveRequest] Received CRequest 11 ref=1
1319269444 -> [CDispatcher::onIncomingRequest()]
1319269444 -> [CDispatcher::processRequestFromManagerIndex()] start at index 0
1319269444 -> 102 [CCallManager::onIncomingRequest()]
1319269444 -> 1113 [CCall::receiveRequest] INVITE
1319269444 -> 1113 [CCall::getDialog] Confirmed Dialog is not found (ID = ;48913e83c59761eacf82a1a1b6c38573)
1319269444 -> 1513 [CDialog::receiveRequest]
1319269444 -> 1513 [CDialog::receiveInviteRequest]
1319269444 -> 11 [~CRequest] req af61c15f5e934e921d4a9da57881c354@192.168.104.246 1016698335 INVITE
1319269448 -> [ipc_thread] IPC Thread : Ipc reception.
1319269448 -> [ipc_thread] IPC Thread : TCL thread signaled.
1319269448 -> [exec_ipc] in.
1319269448 -> [display_ipc_in] ------------ Begin ---------------
1319269448 -> neqt : 1613
1319269448 -> SIP EQT RELEASED
1319269448 -> [display_ipc_in] ------------- End ----------------
1319269448 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1613.
1319269448 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 1613 has released its equipment.
1319269448 -> [CMotorCall::unRegister] Remove eqt : 1613 from the map.
1319269448 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 1613 erased.
1319269448 -> [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
1319269448 -> [CMotorCallManager::onIncomingEvent] killSession.
1319269448 -> 1113 [CCall::killSession]
1319269448 -> 2113 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1319269448 -> 2113 [CTransaction::changeState] no transaction state
1319269448 -> 1113 [CCall::onKill Session Call manager close is called]
1319269448 -> 1113 [CCall::killSession] notifying the call manager
1319269448 -> 102 [CCallManager::onCallClosed]
1319269448 -> 102 [CCallManager::onCallClosed()] removing from the maps
1319269448 -> [CMotorCallManager::onNotifyCallClosed] Call : af61c15f5e934e921d4a9da57881c354@192.168.104.246 is closed.
1319269448 -> [CMotorCallManager::onNotifyCallClosed] call processResponse.
1319269448 -> [CMotorCall::processResponse] call chooseBestResponse.
1319269448 -> [CMotorCall::chooseBestResponse] pForkedBranch=0x836e338 iResponseCode=2000.
1319269448 -> [CForkedBranch::getResponseCode] response=2000.
1319269448 -> [CMotorCall::chooseBestResponse] next branch.
1319269448 -> [CMotorCall::processResponse] no response found.
1319269448 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1319269448 -> [CCall::onKill] set callmanager to null
1319269448 -> 1513 [CDialog::onTransactionState(pTrans = 2113, previousState = null, currentState = Terminated, reason = None]
1319269448 -> 1513 [CDialog::onTransactionState] dialog is terminated
1319269448 -> 1513 [CDialog::onTransactionState] onDialogClosed
1319269448 -> 1113 [CCall::onDialogClosed]
1319269448 -> 1113 [CCall::onDialogClosed] only initial *********
1319269448 -> 1113 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
1319269448 -> D [~CResponse] resp(100) af61c15f5e934e921d4a9da57881c354@192.168.104.246 1016698335 INVITE
1319269448 -> 102 [CCallManager::removeGarbage] at index i = 0
1319269448 -> [CMotorCall::~CMotorCall] Call : af61c15f5e934e921d4a9da57881c354@192.168.104.246 is being destructed.
1319269448 -> 1113 [CCall::~CCall]
1319269448 -> 1113 [CCall::removeGarbage]
1319269448 -> 1513 [CDialog::~CDialog]
1319269448 -> [---*--- SESSION-TIMER ---*---] Free CSessionTimerContext
1319269448 -> 10 [~CRequest] req af61c15f5e934e921d4a9da57881c354@192.168.104.246 1016698335 INVITE
1319269456 -> [info : CTransport::setConnectionEntry(192.168.104.246,49151,0)]
1319269456 -> info : CTransport::receiveUdpProc() from 192.168.104.246:49151 prot:0 rc:381 msg:2
1319269456 -> info : CTransport::DoSTest(192.168.104.246,49151,0) NbMsg:2 < seuil
1319269456 -> RECEIVE MESSAGE FROM NETWORK (192.168.104.246:49151 [UDP])
CANCEL sip:2005@192.168.15.246 SIP/2.0
User-Agent: OxO GW
CSeq: 1016698335 CANCEL
Max-Forwards: 70
Content-Length: 0
1319269456 -> 12 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
1319269456 -> [CIOCom::receiveRequest] Received CRequest 12 ref=1
1319269456 -> [CDispatcher::onIncomingRequest()]
1319269456 -> [CDispatcher::processRequestFromManagerIndex()] start at index 0
1319269456 -> 102 [CCallManager::onIncomingRequest()]
1319269456 -> [CMotorCallManager::callFactory] For call : af61c15f5e934e921d4a9da57881c354@192.168.104.246.
1319269456 -> [CMotorCall :: CMotorCall()]. Start!
1319269456 -> [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmiPCX Enterprise R7.1 f5.401.36
1319269456 -> 1114 [CCall::receiveRequest] CANCEL
1319269456 -> 1114 [CCall::getDialog] Confirmed Dialog is not found (ID = ;48913e83c59761eacf82a1a1b6c38573)
1319269456 -> 1114 [CCall::getDialog] Returning Initial Dialog Server
1319269456 -> 1514 [CDialog::receiveRequest]
1319269456 -> 1514 [CDialog::receiveCancelRequest]
1319269456 -> 2114 [CTransaction::changeState] STATE CHANGED TO INITIAL
1319269456 -> 2114 [CTransaction::changeState] notifying the parent dialog
1319269456 -> 1514 [CDialog::onTransactionState(pTrans = 2114, previousState = Terminated, currentState = Initial, reason = None]
1319269456 -> 2114 [CTransInitialState::receiveRequest] Transaction changes to Trying state
1319269456 -> 2114 [CTransaction::changeState] STATE CHANGED TO TRYING
1319269456 -> 1514 [CDialog::onTransactionState(pTrans = 2114, previousState = Initial, currentState = Trying, reason = Request reception]
1319269456 -> 1514 [CDialog::receiveCancelRequest] No tansaction to cancel
1319269456 -> 1114 [CCall::onDialogClosed]
1319269456 -> 1114 [CCall::onDialogClosed] only initial *********
1319269456 -> 1114 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
1319269456 -> 1114 [CCall] closed
1319269456 -> 102 [CCallManager::onCallClosed]
1319269456 -> 102 [CCallManager::onCallClosed()] removing from the maps
1319269456 -> [CMotorCallManager::onNotifyCallClosed] Call : af61c15f5e934e921d4a9da57881c354@192.168.104.246 is closed.
1319269456 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1319269456 -> 102 [CCallManager::onIncomingRequest()] E_MGR_NOT_AFFECTED, for call af61c15f5e934e921d4a9da57881c354@192.168.104.246
1319269456 -> 103 [CCallManager::onIncomingRequest()]
1319269456 -> 1115 [CCall::receiveRequest] CANCEL
1319269456 -> 1115 [CCall::getDialog] Confirmed Dialog is not found (ID = ;48913e83c59761eacf82a1a1b6c38573)
1319269456 -> 1115 [CCall::getDialog] Returning Initial Dialog Server
1319269456 -> 1515 [CDialog::receiveRequest]
1319269456 -> 1515 [CDialog::receiveCancelRequest]
1319269456 -> 2115 [CTransaction::changeState] STATE CHANGED TO INITIAL
1319269456 -> 2115 [CTransaction::changeState] notifying the parent dialog
1319269456 -> 1515 [CDialog::onTransactionState(pTrans = 2115, previousState = Terminated, currentState = Initial, reason = None]
1319269456 -> 2115 [CTransInitialState::receiveRequest] Transaction changes to Trying state
1319269456 -> 2115 [CTransaction::changeState] STATE CHANGED TO TRYING
1319269456 -> 1515 [CDialog::onTransactionState(pTrans = 2115, previousState = Initial, currentState = Trying, reason = Request reception]
1319269460 -> 1515 [CDialog::receiveCancelRequest] No tansaction to cancel
1319269460 -> 1115 [CCall::checkAuthentication] CANCEL
1319269460 -> 1115 [CProxyCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
1319269460 -> 1115 [CProxyCall::onReceiveRequest]
1319269460 -> [CGWMngData::isMainServer] CPU is MAIN.
1319269460 -> 1115 [CPoxyCall::onReceiveRequest] No target for the service send : 404
1319269460 -> 1115 [CCall::makeGenericResponse] 404
1319269460 -> 1115 [CCall::getDialog] Confirmed Dialog is not found (ID = ;48913e83c59761eacf82a1a1b6c38573)
1319269460 -> 1515 [CDialog::createResponse] 404
1319269460 -> 2115 [CTransTryingState::createResponse] CResponse E ref=1
1319269460 -> E [CMessage::send] sip_sendMessage (192.168.104.246:5060)
1319269460 -> SEND MESSAGE TO NETWORK (192.168.104.246:5060 [UDP]) (BUFF LEN = 326)
SIP/2.0 404 Not Found
Content-Length: 0
1319269460 -> info : CTransport::createConnectionUdp 192.168.104.246 5060
1319269460 -> [info : CTransport::setConnectionEntry(192.168.104.246,5060,0)]
1319269460 -> 2115 [CTransTryingState::createResponse] Final : Transaction changes to Completed state
1319269460 -> 2115 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1319269460 -> 2115 [CTransaction::changeState] notifying the parent dialog
1319269460 -> 1515 [CDialog::onTransactionState(pTrans = 2115, previousState = Trying, currentState = Completed, reason = Final resp creation]
1319269460 -> 2115 [CTransaction::startTimer] Timer J is started (delay = 115200 ms)
1319269460 -> 1515 [CDialog::updateRouteSet] there are 0 record-route headers
1319269460 -> 102 [CCallManager::removeGarbage] at index i = 0
1319269460 -> [CMotorCall::~CMotorCall] Call : af61c15f5e934e921d4a9da57881c354@192.168.104.246 is being destructed.
1319269460 -> 1114 [CCall::~CCall]
1319269460 -> 1114 [CCall::removeGarbage]
1319269460 -> 1514 [CDialog::~CDialog]
1319269464 -> main.trace.timer = 480mn
When we try to call from oxe to oxo, we are getting the message below;
(1)xa000000> 25/10/11 11:39:33 000001M|--/--/-/---|=0:1721=Phone exc 14, PC 0x085a2cc6 neqt 1677
(527847:002754) Application-exception no 14, thd 1202, PC=HYB_SigOnComp(short, unsigned char), eqt=1677, serv=0
(527847:002755) * Backtrace: 0x085a2dd7:140127703 EBP 0x01816df8 --> HYB_JonctOnComp(short) (+203) 93%
(527847:002756) * Backtrace: 0x082e701b:137261083 EBP 0x01816e14 --> uti_inidcom(unsigned char) (+3843) 71%
(527847:002757) * Backtrace: 0x082e7809:137263113 EBP 0x01816e50 --> inidcom(unsigned char) (+337) 9%
(527847:002758) * Backtrace: 0x082e76b3:137262771 EBP 0x01816ec4 --> inidcom(void) (+123) 96%
(527847:002759) * Backtrace: 0x087af73b:142276411 EBP 0x01816ed8 --> prise_q931(void) (+723) 78%
(527847:002760) * Backtrace: 0x091e85f8:152995320 EBP 0x01816ee4 --> real_main (+3496) 88%
(527847:002761) GS=00000000 FS=00000000 ES=0000002b DS=0000002b
(527847:002762) EDI=01817440 ESI=0000000d EBP=01816df8 ESP0=00000000
(527847:002763) EBX=00000013 EDX=00000000 ECX=2502068c EAX=00000000
(527847:002764) EIP=085a2cc6 CS=00000023 ESP3=01816df8 EFLAGS=00010256
(527847:002765) B(33913:001) Eqt=01677 Emi=00431 {20004, 05903, 0x87af468} wait=0x000000,0x000000
(527847:002766) B(33913:002) Eqt=00431 Emi=01124 {20001, 00003, 0x898d688} wait=0x898d664,0x000000
(527847:002767) B(33910:004) Eqt=00431 Emi=01124 {20001, 00003, 0x898d688} wait=0x898d664,0x000000
(527847:002768) B(33897:014) Eqt=00431 Emi=00000 {00000, 00000, 0x8b5f708} wait=0x000000,0x000000
(527847:002769) Restarting at PC=real_main, with stack=0x01817ff8:25264120
(527911:002770) Application-exception no 14, thd 1202, PC=HYB_SigOnComp(short, unsigned char), eqt=1613, serv=0
(527911:002771) * Backtrace: 0x085a2dd7:140127703 EBP 0x01816dc8 --> HYB_JonctOnComp(short) (+203) 93%
(527911:002772) * Backtrace: 0x082e701b:137261083 EBP 0x01816de4 --> uti_inidcom(unsigned char) (+3843) 71%
25/10/11 11:39:39 000001M|--/--/-/---|=0:1721=Phone exc 14, PC 0x085a2cc6 neqt 1613
(527911:002773) * Backtrace: 0x082e7809:137263113 EBP 0x01816e20 --> inidcom(unsigned char) (+337) 9%
(527911:002774) * Backtrace: 0x082e76b3:137262771 EBP 0x01816e94 --> inidcom(void) (+123) 96%
(527911:002775) * Backtrace: 0x091437ad:152319917 EBP 0x01816ea8 --> arr_sip(void) (+45) 5%
(527911:002776) * Backtrace: 0x091e85f8:152995320 EBP 0x01816ee4 --> real_main (+3496) 88%
(527911:002777) GS=00000000 FS=00000000 ES=0000002b DS=0000002b
(527911:002778) EDI=01817440 ESI=0000000d EBP=01816dc8 ESP0=00000000
(527911:002779) EBX=00000013 EDX=00000000 ECX=2502064c EAX=00000000
(527911:002780) EIP=085a2cc6 CS=00000023 ESP3=01816dc8 EFLAGS=00010256
(527911:002781) B(33976:001) Eqt=01613 Emi=00000 {00000, 10752, 0x9143780} wait=0x000000,0x000000
(527911:002782) Restarting at PC=real_main, with stack=0x01817ff8:25264120
Also i can't create a new sip trunk group. I'm getting the error message below.
"Trunk Group ID : No free Hybrid Bus Access"
Anyone have any idea?
Thanks in advance.
SIP trunk fail
Re: SIP trunk fail
Do you have a backup of the chorus data try to restore that one as well.
The error "Trunk Group ID : No free Hybrid Bus Access" can be solved at the following way:
cdmao
cfgUpdate
option number 5 increase the number of trunks with 200 or more.
reboot system.
cdmao
cfgUpdate
reboot system.
burzum07
Re: SIP trunk fail
Post by burzum07 »
MrAnMo wrote:Do you have a backup of the chorus data try to restore that one as well.
cdmao
cfgUpdate
reboot system.
I've already restored chorus data a couple of times but still doesn't work :/
Any other suggestion?
root
Re: SIP trunk fail
Post by root »
the backtrace is a call handling issue, check what is neqt 1613 and make traces on cr 19 with mtracer
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
