ISDN Outgoing with PIN Code
sylvesterperalta
Post by sylvesterperalta »
Hi Team,
We are having some problem on our ISDN Trunk Line for outgoing calls. The ISDN Service provider informed us that to be able to call Mobile, NDD and IDD calls we need to include the following PIN codes 10610 for US numbers and 10610011 for Non US numbers.
We are trying to add the provided digits with the ARS configuration but unfortunately it is not working. We can't find a way we can add the digits with the ARS just like the OXE configuration.
I would like to know if there is other possible way to add the PIN codes so we just dial 9 for outgoing + Number Required. Is there anyone already test the ARS configuration in OXO Release 8.0
Need advice.
Best regards,
Rocky
Re: ISDN Outgoing with PIN Code
You need to use Command Tables with ARS routes. check the system documentation regarding configuration.
sylvesterperalta
Thank you very much for the advice, I will check the Command Tables in the System Documentation Manual.
