qsig trunk access delay
alcatelboy
Post by alcatelboy »
see my config
prefix setting to : Professional trunk seize
system : overlap seizure +true
trunnk groups:overlap dialing +No
discriminator rule: call number:9 number of digits:9
now i dialing :prefix +983075100 then delay about 15S can sent to the trunk.
system version:I160521
how can i do?
thx
AQPS ACFE ACSE
Re: qsig trunk access delay
For me - right management:
prefix setting to : Professional TG seize with overlapping
system : overlap seizure +true (or no - if you need dialing in block mode)
alcatelboy
thx vad
had done ,i use the ars to inserted "#" .command tab :I#
AQPS ACFE ACSE
mani23
Post by mani23 »
Hi how did you do that?more explain please i have the same problem
Return to “MAIN”
