ACCOUNTING: Appli ACC_ETH : feature incident 2 3
dryhouse
Post by dryhouse »
Hi guys;
I have this incident in my system.4760 receive the tickets and work ok.
16/11/11 06:43:43 000099M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACC_ETH : feature incident 2 3
16/11/11 06:43:43 000099S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACC_ETH : feature incident 2 3
16/11/11 07:23:42 000099M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACC_ETH : feature incident 10 0
the meaning of the incident does not explain well:
2 BUF_OVERFLOW. The ethernet buffer is full."
" P3 is equal to 3 (ethernet thread)."
(10, 0) Operation to be done again with coherent data."
Any idea? Thanks for your Replies.
Re: ACCOUNTING: Appli ACC_ETH : feature incident 2 3
Files for external accounting (used by 4760) and real time ticket output (via ethernet) - not the same.
Check application / accounting - managed or not "on-line printing" and used or not.
dryhouse
Post by dryhouse »
Hi vad, thanks for your replie,
I check application/accounting:
internal accounting-->yes
Files for external accounting-->yes
outpout in real time-->no
tickets storage--> no
Only 4760 receive the tickets. The configuration is ok?
Regards.
luis.molinas
Post by luis.molinas »
Hi dryhouse,
I have the same incident. Can you solved this?
luis.molinas
Sorry, I correct myself.
The same incident to the 0275=ACCOUNTING: Appli ACC_ETH : feature incident 10 0
dryhouse
Post by dryhouse »
Hi Luis,
The incident has been corrected with
IP tickets over ethernet: NO and
real time tickets output: NO
Your incident means: a bad date in your PBX
Regards.
luis.molinas
Ok, thanks dryhouse!
I changed "IP tickets over ethernet to NO" and the incident has been solved.
kishore1942
Post by kishore1942 »
Hi People,
I have the same Issue, the IP phones keep restarting.
09/12/21 16:28:17 000001S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACC_ETH : feature incident 2 3
09/12/21 16:28:22 000001M|001/00/0/134|=3:0386=Sig. on IP set: No response from de set 00:80:9f:22:4f:7d,5517
09/12/21 16:28:58 000001M|---/--/-/---|=2:0283=ACCOUNTING. Appli CALLHANDLING : feature incident 2 527
09/12/21 16:29:12 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:ee:4f:7d,5517
In Applications
Internal Accounting + YES
Tracking + YES
Financial Report + YES
CDR Tickets Storage + YES
Files for External Accounting + YES
Real Time Tickets Output + NO
regards,
KK
You have more then one problem.
09/12/21 16:28:17 000001S|---/--/-/---|=2:0275=ACCOUNTING: Appli ACC_ETH : feature incident 2 3 - incident from stand-by CPU. May be on twin CPU you have Real-time tickets=yes?
09/12/21 16:28:58 000001M|---/--/-/---|=2:0283=ACCOUNTING. Appli CALLHANDLING : feature incident 2 527 - you have duration accounting. For dialed number started from 527 - not managed charge scale.
09/12/21 16:29:12 000001M|000/00/0/000|=4:0426=IPTOUCH terminal reset 13,00:80:9f:ee:4f:7d,5517 - just problem with IP set - check your network - management, cabling etc.
kishore1942
thanks for your time Vad, will consult my epabx engineer and will revert.
KK
Return to “Application”
