NAT
ram
NAT
Post by ram »
Please anyone let me know which switch will be support nat features.
Senbagaram.k
one6f
Re: NAT
Post by one6f »
6850 doesn't support NAT. The OmniSwitches can't work as NAT router, at least in version AOS 6. Previous 7000/8800 (release 5) supported simple NAT rules using QOS polices, such as "rewrite ip". For NAT support you may first want to look at OmniAccess series or firewalls.
ram
Re: NAT
Post by ram »
thanks one6f, if i upgrade the aos in 6850 means it will support nat ...?
murraya
Re: NAT
Post by murraya »
No, current versions of 650 do not support NAT. Omniaccess like the OA5510 are used for this function.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
ram
Re: NAT
Post by ram »
Hi murray,
thanks man, shall i go for alcatel omni access 740 router for nat ...?
