Problem with calculate cost for OmniVista 4760
Tan Phu
Post by Tan Phu »
Dear All!
I encounter the problem when i tried to print out the telephone bill for my customer: They are using OmniVista R5.2 for OXE R9.1, just in mettering mode (license). The Call Records are include called number, duration, ext... but without cost in spite of I have already created the carrier, tariff,...
Does any one get this problem before?
Thanks advanced for the helps.
Regards!
Phu
angelo0716
Re: Problem with calculate cost for OmniVista 4760
Post by angelo0716 »
Hi!
I'm having the same problem...anybody who can help us on this issue? Appreciate ur attention.
siti
Post by siti »
I am facing the same problem too. this is OV R5.2.01.03.
There is no lift to success.You have to take the stairs - one at a time.
Zero
Post by Zero »
Hi guys,
What is the status of your concerns?
If I may add, were you able to manage the PCX field under the created Regions?
I hope this helps.
Thanks,
Zero
Return to “4760”
