auto delete company directory with system directory
ybelal
Is it possible that deletion of any extension from system in 4760 will be updated/deleted from company directory automatically? If yes, please help to know the settings/configuration.
Re: auto delete company directory with system directory
What is company directory?
The Phonebook? A LDAP or similar?
If PB then it 's deleted automatically.
If Third party, i don't think so.
ybelal
It's not a third party application. It's a 4760 application.This company directory is used for omnivista 4760 webdirectory.
luckyme2
No,
If you delete the system entry, only the LINK from system directory to the company directory is deleted. The entry in the company directory will remain available. If you want the entry to be deleted in the company directory, you need it to do using LDAP scripting.
The deleted entry in the system directory will be restored after a synchro between Pbx and Omnivista.
Cheers,
Cheers,
zanex
dont know if this will help but i know that alcatel professional services wrote an app that hooks between 4760 and active directory for user creation but dont know if it did deletion
Once the system does an auto sync of a night the user will go...as long as you havent changed the 4760 settings...
