4635 Install guide
intheskin
4635 Install guide
Post by intheskin »
Do someone have a install howto for 4635 ?
ALU doc says I should refer to paper book 3BA 19943 for version 1.3.1 !!!
I suppose it is ethernet boot from 4635 on a PC with TFTP but need for more info as I do not have one VPM35 to play with before doing it for real...
I am contining on you !
Seb.
alex
Re: 4635 Install guide
Post by alex »
It is in /docs folder on your 4635 CD.
prasanna_s3
Post by prasanna_s3 »
give me u mail id
i will send the doc
hung.le
Post by hung.le »
prasanna_s3 wrote:give me u mail id
i will send the doc
dear prasanna_s3,
Could you send me 4635 doc?
My email: bkct11@gmail.com
Sincerely thanks!
wallacezammit
Post by wallacezammit »
can you please also send me the documentation file of the installation procedure of 4635?
My email is wallewils@gmail.com
Thanks and Regards
Wallace
dmode
Post by dmode »
Could someone send me the doc file for 4635J?
davmei@singnet.com.sg
David Mei
kalel
Post by kalel »
i will send the doc
hi prasanna_s3
can i have a copy of the documentation...
email : kalel_p3@yahoo.com
thanks
wallacezammit
Hi Kalel,
you can check this post also
http://alcatelunleashed.com/viewtopic.php?f=280&t=20267
Wallace
Return to “Voicemail (46x5)”
