Configure OXO for 4135 IP Conference Phone
ncedomir
We have bought new 4135 IP Conference Phone. I have VoIP subscriber licences. I configure on the OXO the extension that should be 4135 with MAC address and SIP password.
Next i write the sip values on the 4135 and reboot the device to register. The registering is failing no matter what i do.
In SIP trace i saw few errors that i'm sending to you guys now. Also few pics of licences and conf screen. Can someone help me regarding this issue.
BR,
BR,
ncedomir
Re: Configure OXO for 4135 IP Conference Phone
Also my software release is:
3EH30404EEAA ALZBG810/051.001
hi, i was not directly involved in this but one of our engineers was having the same issue. I overheard him say he fixed it by updating the 4135 with new firmware. I know the OXO was 810 (not sure of patch level though.
Suggest you check the version of the 4135 with whats on the BPWS.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Hi ncedomir
I didn't install this 4135 IP yet, but I installed SIP phones.
OXO listen to the port 5059 and as we can see in your trace, the 4135 IP is trying to register in the port 5060:
Regards.
Then, you receive a message from OXO where it answers 501 not implemented:REGISTER/cseq=12770 (tdta0x1f07a0) to UDP 192.168.92.246:5060:
REGISTER sip:192.168.92.246;transport=udp SIP/2.0
Change the configuration of the 4135 IP to register in the port 5059. I believe it will work.Response msg 501/REGISTER/cseq=12770 (rdata0x1e09e4) from UDP 192.168.92.246:5060:
SIP/2.0 501 Not Implemented
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
Do you need SIP licenses to use 4135?
Wouldn't these licenses help in this case? They are used for basic SIP phone too... (see attachment).
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
No, because they don't do conference. The purpose of the 4135 IP. Excuse me...
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
ae225
Base on TC1545-ed02, only standard IP license is required for 4135 Conference phone :
"Limit
If “Open SIP” phones (SIP Phone with associated “Open SIP Phone” license) are configured and used as IP
Conference Bridges, there is a maximum limit of 3 simultaneous SIP conferences bridges managed by OXO
(example 2 OT 4135 + 1 Open SIP Phone configured with SIP Conference Bridge)."
"License
Standard “IP Users” license is used."
Use TC1548 as your guide for installation of OmniTouch 4135. This is with reference that the firmware is 1.5.x.
I have tried on a unit with fw 1.2.x but not successful. The layout 1.2 and 1.5 look different anyway. I download
the bin file from BPWS to upgrade manually, before I am able to connect with OXO. And of course there is OXO
certificate that needs to be exported and imported to 4135.
All these are explained in TC1548.
Good lucks.
Rgds.
"Limit
"License
Good lucks.
Rgds.
malien
Hi, I have successfully register the 4135 Conference phone on the OXO R810/045.003 and
external calls work well without bussines account !! but does not work with bussines account
Can someone help me regarding this issue??
DuboisP
hi,
where can i found TC1548 ?
i have one (to begin) 4135 to install, and i don't know how to do it.
