auto call on lift
geovillage
auto call on lift
Post by geovillage »
Hi , i must set user for Lift Emergency call.
Lift's support ask me to configure a user that automatic call user 8114 when lift ( open the line , sorry for my tecnical English i'm italian :-) ).
Can you help me to find correct secting to do this?
Thanks in advance, Adriano
murraya
Re: auto call on lift
Post by murraya »
hi, there are 3 stages to do this,
1: set up a routing table say number 1
2: setup a tel facility catagory with direct routing set to immediate
3: in the user give them the tel fac catagory and enter the routing table you have configured in the routing table of the user.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
tjm0852
Post by tjm0852 »
Why not put the user in Phone Features COS 31 and make the associated set to 8114. Ring down circuit, so as soon as a switch hook is detected it will ring the associated set.
Maybe I am misunderstandng the question.
tjm0852 wrote:Why not put the user in Phone Features COS 31 and make the associated set to 8114. Ring down circuit, so as soon as a switch hook is detected it will ring the associated set.
They need hotline feature --> Lift emergency button pushed --> off hook --> routing at of hook to predefined number.
geovillage
murraya wrote:hi, there are 3 stages to do this,
I resolve with this solution. Thank you very much to all
michib
Post by michib »
hi,
where can i set the routing table?
best regards,
michi
specific telephone srvices/ routing tables
Return to “Users”
