Does anybody know where I can get an auxillary ringing indicator that is compatible with the NOE (8+9) series phones? I need this for use in a recording studio enviroment where the ringer has been switched off via the prefix, but I need to provide a visual indication of incoming calls. An example of the type of thing I am looking for can be seen on http://www.algosolutions.com/products/v ... index.html although these are not compatible with Alcatel systems.
All suggestions welcome, it will be insatlled on an OXE using crystal hardware,
cheers.
Strobe/visual ringing indicators for digital (NOE) handsets
- frank
Re: Strobe/visual ringing indicators for digital (NOE) handsets
3GV28050AA "Alcatel module relaying the ringing signal towards an external device for Alcatel 8 & 9 series sets, compatible with Reflexes™ range, with RJ11/RJ11 3m cable, without power supply" OEM 242.00
This is what you need. We used it at a customer in the same environment as you, and it worked perfect.
maybe this kit will not work.
i had problems with gn9120-headset on 8&9-phones, if some (don't know which) ringing melodies are selected you can not hear the ringing in the headset. and if you switch off ringing there is also no signaling at the rj11-outlet.
i have a workaround by some of my customers because they forgot to order this kits. make a parallel hunting group with the original phonenumber, put in the 8&9-set and a new analog-set. just put a relais to this analog equipment and you can switch what ever you want.
the 8&9 set must be forworded to the hunting group!!
ACSE OTUC
ACSEOXE
ACSEOXE
