Problem With OTS R10.0.8.2
mohamed-eid
Post by mohamed-eid »
Hello All,
I have installed the CCA server with the help of documentation and all applications has been installed right.
but when I try to launch the (Alcatel OmniPcx OTS manager) it gives me an error says that:
problem with OTS ! ( you don't connect on the OTS of administration)
I don't know what/where could be the fault?
note that, the version of the CCA server is R10.0.8.2
could any one help me???
jasic
Re: Problem With OTS R10.0.8.2
Post by jasic »
You must change 2 dll files when I remember rigth. It is describe in the install guide of CCA.
Return to “OTUC”
