I'm experiencing a problem with internal calls to the GCE service.
When the call get into the queue and waits exactly 30 seconds, the call is dropped.
The problem does not happen with external calls.
Does anyone know how i can fix it?
Thanks.
Internal calls waits only 30 seconds in the queue
- joao.carlos
- joao.carlos
Re: Internal calls waits only 30 seconds in the queue
Anyone?
joao.carlos
ACSE OXE R12 | ACSE OpenTouch R2 | ACSE OXO Connect R2 | ACSE OmniVista 8770 R3 | ACFE OmniSwitch R6/R7/R8 | ACSE OTCS R8.2
ACPS IP Telephony R12 | ACPS OpenTouch R2 | ACPS Data Networks R6/R7 | ACPS OTCS R8.2
joao.carlos
- cavagnaro
TServer/URS logs?
elizabeth.liston
If you havent already found the solution try adjusting timer 9 on the oxe... Ring tone timer: if the person called does not answer before this timer elapses, the caller gets the busy tone.
Timer for ringing before overflow on internal call (as of R4.2).
