Problems with the configuration of AA Menu
elias_ruiz_diaz
Please, when i'm configuring the AA menu in the OXO, i see i only can create one "submenu", i mean, when i'm loading the options (option 1 for example), i put "sub menu" there, but when i go inside "sub menu" don't let me to create another "submenu" inside this "submenu", is posible this?, please, if someone knows how, please tell me! thanks
- tot3nkopf
Re: Problems with the configuration of AA Menu
AA allowes only two levels. You need MLAA for more than that.
elias_ruiz_diaz
now i got the MLAA license, and i don't know what to do to change the normal AA by the MLAA, do you now? please, if you can explain me step by step is going to be awesome!! i was searching about this configuration for days in a lot of places, if you now how to implement, please say me!tot3nkopf wrote:AA allowes only two levels. You need MLAA for more than that.
- tot3nkopf
You have all that explained in the System Doc.
elias_ruiz_diaz
that explanation is for the normal AA, not for mlaa..
elias_ruiz_diaz
for activating the mlaa i have to disable the basic AA hitting in "disable voice processing"? or i don't have to be worried about the "ex" AA? actually i have activated the integral voice processing, but i wanna change it by the MLAA, and this change i don't know how to do. i don't know which attendant groups or hunting groups to use..
- tot3nkopf
Do you see the ACD services in OMC? Did you upload the ACD service packages with LoLa?
In OMC help search for MLAA.
elias_ruiz_diaz
no because ACD has an apart license of MLAA and i don't have, i have to get both to make the mlaa work? i have to necessarily buy the ACD license?
- tot3nkopf
MLAA is built on ACD engine. You need to upload that packages.
elias_ruiz_diaz
i have to buy that license? what is "LoLa"?
