Error reporting- omnivista 4760
elias_ruiz_diaz
Post by elias_ruiz_diaz »
Hi!
I have this problem in the omnivista, is in spanish sorry, if someone had this error, please! help me! i need it..
I wait for the response.
Thanks!
mavijitr
Re: Error reporting- omnivista 4760
Post by mavijitr »
is it a customized report?
the report is not good some of the information is missing or introduced formula may be wrong or multiple filter with same database field.
mavijitr
Post by mavijitr »
report generation failure due to max number of lines...
elias_ruiz_diaz
Thanks for your response!
Yes, is about a customized report, with the default reports i have the same error.
It's the second time that happen to me this problem.. for the first time i unistall completely the omnivista and i started to personalize the reports and work, two months later i have the same trouble again..
mavijitr
Post by mavijitr »
i am not sure what kind of report is this? is this related to accounting or traffic? pls use proper filter in both the case and do not use the same database field for multiple function which is not allowed. no need to uninstall and reinstall.. just remove the report. and recreate it enough.
KIKA
Post by KIKA »
Does somebody solved without reinstall or recreate the report?
It just happended to me. Of course I restarted the Server, after that, again Report Error in all reports.
But suddenly... I tried again and were all the reports OK. :)
What happened? :shock:
Return to “OmniVista 4760”
