There is no audio in audio conference
enio.eltz
Post by enio.eltz »
I could install My Teamwork in a vmware and connect it with my OXO.
I created the SIP trunk from OXO to My Teamwork (6000, 6001, 6002 and 6003 are the numbers in OXO that call conference center with their own languages). I can call from any OXO set to those numbers succesfully, I listen to language prompts succesfully.
I can open user web interface, log in, use IM, apllication sharing, etc.
The problems are:
I call 6000 (Portuguese prompt) from the OXO set, and dial the conference code. When my co-worker calls 6000 and dials the same conference code, sometimes we talk to each other for a few seconds, after this there is no audio. sometimes, always there is no audio.
when I call an user with web interface user, the same happens.
There are traces available. Any help is useful.
Thanks.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Re: There is no audio in audio conference
Codecs Enio, check codecs
enio.eltz
Post by enio.eltz »
Hi Cavagnaro
Yes, I checked them. Teamwork is configured as G729 for first option. In OXO, it is predefined, G729, right?
As I wrote, I start a call with user web interface, we can talk to each other for 5 seconds, a little time, in my understanding codecs should be right.
Thanks.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Nop, you didn't say that... ;) check it
Well if you do have audio sometimes then...maybe RTP packets lost? Same VLAN? Same network segment?
Have you done a TCPDump (Wireshark) and see why the call drops? The disconnect message and reason must be there
Return to “My Teamwork (ex-eDial)”
