INTIP B in INT_HS
Schpice
INTIP B in INT_HS
Post by Schpice »
Hello Everybody,
I have just noted something on my crystal, I have a link role with one of both INTIP B which is in INT_HS (see below).
Somebody can told if it's normal ?? What happen if I switch from INTIPB cpl 10 to cpl 6 ?? I don't understand, my INTIP board is well IN SERVICE.
(1)pabx_a> config 2
Fri Oct 5 11:03:55 CEST 2012
| 2 | 0 | NPRAE|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 1 | NPRAE|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 2 | INTIPA| INT-IP | REG NOT INIT | NO PCMS CODE |
| 2 | 3 | NDDI2|---------- | IN SERVICE | 3BA23171ABBE02 |
| 2 | 4 | INTIPA| INT-IP | IN SERVICE | 3BA23193ACAF07 |
| 2 | 5 | GPA2|---------- | OUT OF SERV | 3BA23241AAAC05 |
| 2 | 6 | INTIPB| INT-IP | IN SERVICE | 3BA23193ACAF06 |
| 2 | 8 | eZ32|---------- | IN SERVICE | 3BA23265ABCB04 |
| 2 | 9 | GPA2|---------- | IN SERVICE | 3BA23241AAAC05 |
| 2 | 10 | INTIPB| INT-IP | IN SERVICE | 3BA23193ACAF07 |
| 2 | 11 | GPA2|---------- | IN SERVICE | 3BA23241AAAC05 |
| 2 | 12 | BRA2|---------- | IN SERVICE | 3BA23073ABJD04 |
--- Inter Crystal Topology ---
| CR | CPL Type Role Free/Tot Role Type CPL | CR |
|002 | 06 -INTIPB (STANDBY) === 55/60 === ( INT_HS) INTIPA - 01 |019 |
|002 | 10 -INTIPB (MAIN ) --- 53/60 --- ( INT_A) INTIPA - 01 |019 |
Thanks in advance
Kévin
Re: INTIP B in INT_HS
Do:
config 1
see position 19 status
Return to “Boards”
