wrond hard key
youfo007
wrond hard key
Post by youfo007 »
I switched my PBX version 2 version 6.1 by changing the cpu to CPU6.
when I log with mtcl, it gives me a message "wrang hard key" and after it displays a message that I have 30 days!
I check it on ops and I found the code on the dongle is not on the same version of ops.
my question is how can I delete old ops to install those compatible, because when I connect with ftp I try to delete the folder / usr4/buckup/immed/ops, it gives me that it is impossible???
thank you.
murraya
Re: wrond hard key
Post by murraya »
hi, do not delete the folder just delete the files in that folder and copy your new OPS files (*.sw, *.hw and *.zip) then run swinst to load the new OPS.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “Other”
