IP touch 4028 with TRIX BOX
a_nair
Dear Friends,
I need to know some important possibilities regarding of IP touch phone 4028 with TRIX BOX .Here TRIX BOX is a IP PBX based on Asterics.It having some ip phones itself.I need to accommodate Ip 4028 phones in to that PBX.Is it compatable? iF so how can we connect? If not what solution we can give?
With thanks & Regards
a_nair
a_nair
xbelond
Re: IP touch 4028 with TRIX BOX
I have the solution.
If you speak french i can try to explic the proced.
xbelond
en français,
Bonjour, je vais essayer de vous apporter une réponse,
Il vous faut monter un serveur tftp pour envoyer la configuration au telephone.
pressez "i"+"#" durant la séquence de démmarage. dans les parametres ip vous passez en static, et vous renseignez l' ip, le masque, et le serveur tftp.
sur votre serveur tftp : vous faites un fichier de configuration qui porte le nom :
"sipconfig-mac_address_phone.txt" sans les ":" ex: sipconfig-00809fa4fd46.txt
je vous join ce fichier.
In English,
Hello, I'll try to answer,
You must set up a tftp server to send the configuration on the phone.
press "i" + "#" in the sequence Starter. parameters in the static ip you enter, and you fill the ip, mask, and the TFTP server.
on your tftp server: you make a configuration file named:
"sipconfig mac_address_phone.txt-" without ":" ex: sipconfig-00809fa4fd46.txt
I'll join this file.
In English,
a_nair
Dear xbelond,
Thanks for your valuable reply and can you tell me
How can we setup TFTP server?
a_nair
a_nair
xbelond
on your server you have a directory "" tftpboot "it is sufficient to put the txt file and specify the phone good tftp server.
sur votre serveur vous avez un repertoire ""tftpboot"' il suffit d'y mettre le fichier txt et de spécifier sur le telephone le bon serveur tftp.
indigo926
Dear xbelond,
I am having problems with my 4028 SIP software version: 2.01.20
1/5 Network start
2/5 Network setup
3/5 config download
gen conf file proc.
Invalid Parameters!
reset... please wait and reboots itself
I see that it downloads two files sipconfig.txt and sipconfig-macaddress.txt from the tftp server. Both files are identical and taken into account because asks for the admin password what I set. I do not have proxy, just a registrar for my sip server.
Do you have any idea how can I continue?
Merci en avance!
1/5 Network start
2/5 Network setup
3/5 config download
gen conf file proc.
Invalid Parameters!
Merci en avance!
indigo926
I sorted out the configuration issue (based on the R10.0 documentation): the config should have valid sip proxy.
Now the next problem: the 4028 registers correctly at boot time, but after the expiration of the registration shows "No regist" and does not re-register. (Even having retry set to 3000)
The same is happening after network problem: no re-registration
Anybody has any idea how the re-registration could be forced in the sipconfig.txt
Thanks in advance
Thanks in advance
davide_patriarca
I'm facing the same exact problem... The phone doesn't send the REGISTER when "register_expire" expires...
Any clue?
Any clue?
Afftobus
As I know, SIP is possible in software version 4.x
I have a lot of Alcatel 40x8 phones with 3.9x ver, but im tired of alcatel and i want to use just SIP.
Can I upgrade my phones without upgrade my Omni PCX Office?
voipsystems
Hi i was having the same issue, i try different things, but in these page http://alcatelunleashed.com/viewtopic.p ... 0&start=20, you can see an example it works good, the timezone is not the correct for me, but is not un registering each 20 or 1 hour, im checking the pool timer for no reboots, but right know if reboots register fine
davide_patriarca wrote:I'm facing the same exact problem... The phone doesn't send the REGISTER when "register_expire" expires...
Any clue?
