Configure MyIC as Business user with OXE R
I need to configure MyIC as a business user with OXE Release 10.0.
So can any one provide me with templates for the following files
Config.mac-address.xml
Profile.mac-address.xml
sipdata.mac-address.xml
alex12555
Re: Configure MyIC as Business user with OXE R
Here you are, but without guarantee
For me it is so "almost" perfect without the 8770!
I would only like to do the Factory Default on the 8082!
Have fun Alex
config.mac.xml:
profile.mac.xml:
sipdata.mac.xml:
custom.xml:
Have fun Alex
config.mac.xml:
<?xml version="1.0" encoding="UTF-8" ?>
<settings>
<setting id="DmEnetcfgSipFile" value="/sipdata.mac.xml" override="true"/>
<setting id="DmEnetcfgOptionalFile" value="/config/custom.xml" override="true"/>
<setting id="DmEnetcfgUpgradeFile" value="/config/profile.xml" override="true"/>
<!-- NTP IP Address (CallServer) -->
<setting id="DmEnetcfgSntp" value="xx.xx.xx.xx" override="true"/>
<!-- Admin Password -->
<setting id="DmAdminPasswd" value="*tx8000#" override="true"/>
<!-- Enable SSH -->
<setting id="DmSecucfgSsh" value="true" override="true"/>
<setting id="DmAdmcfgUpdatePollingEnable" value="true" override="true"/>
<setting id="DmAdmcfgUpdatePollingTimeout" value="3600" override="true"/>
<setting id="DmAdmcfgCfgfilePollingEnable" value="true" override="true"/>
<setting id="DmAdmcfgCfgfilePollingTimeout" value="200" override="true"/>
<setting id="DmAdmcfgUpdateTimeEnable" value="true" override="true"/>
<setting id="DmAdmcfgUpdateTimeStart" value="03:30" override="true"/>
<setting id="DmAdmcfgUpdateTimeDelta" value="10" override="true"/>
<setting id="CurrentEnetcfgSntpRefreshPeriod" value="3600" override="true"/>
<!-- PC LAN Port Disabled / Enable -->
<setting id="LocalEthlcfgPcEnable" override="true" value="true" />
<setting id="DmAdmcfgTimeZone" value="Europe/Brussels" override="true"/>
<setting id="RegularResetActive" value="true" override="true"/>
<setting id="RegularResetSchedule" value="7200" override="true"/>
</settings>Code: Select all
<?xml version="1.0"?>
<profile>
<name>Official BO</name>
<key>./key.xml</key>
<component>
<name>weather</name>
<version>0.0.1.1</version>
<url>/config/repository/Weather-0.0.1.1.signed.zip_content/index.xml.weather.0.0.1.1.signed</url>
<checksum type="md5">05a9ba3792b38e10e0432ef217afae95</checksum>
</component>
<component>
<name>MyICPhone_8082_Release R250.01.010.3</name>
<version>R250.01.010.3</version>
<url>/config/repository/ICTouch_VHE_R250_01_010_3.zip_content/index.xml.signed</url>
<checksum type="md5">e8fdb0de3279a8a3c6936105f21c8fae</checksum>
</component>
</profile>Code: Select all
<settings>
<!-- SIP UserName -->
<setting id="SIPUserName" value="1234" override="true"/>
<setting id="SIPDeviceUri" value="1234" override="true"/>
<setting id="SIPAuthenticationName" value="1234" override="true"/>
<setting id="SIPGroup1DeviceUri" value="1234" override="true"/>
<!-- Language EN
<setting id="Language" value="0" override="true"/> -->
<!-- Language DE -->
<setting id="Language" value="5" override="true"/>
<!-- Call Server IP -->
<setting id="SIPProxyAddress" value="xx.xx.xx.xx" override="true"/>
<setting id="SIPRegistrarAddress" value="xx.xx.xx.xx" override="true"/>
<setting id="SIPServer1Address" value="xx.xx.xx.xx" override="true"/>
<!-- <setting id="SIPPhoneStateNotifyUri" value="xx.xx.xx.xx" override="true"/> -->
<setting id="SIPMessageWaitingIndicationUri" value="1234@xx.xx.xx.xx" override="true"/>
<setting id="SIPAuthenticationRealm" value="xx.xx.xx.xx" override="true"/>
<setting id="SIPGroup1AuthenticationRealm" value="xx.xx.xx.xx" override="true"/>
<!-- SIP Display Name -->
<setting id="SIPDisplayName" value="Name, first name" override="true"/>
<setting id="SIPGroup1DisplayName" value="1234" override="true"/>
<!-- SIP Password -->
<setting id="SIPAuthenticationPassword" value="0000" override="true"/>
<setting id="SIPGroup1AuthenticationPassword" value="0000" override="true"/>
<setting id="SIPPhoneStateNotifyType" value="0" override="true"/>
<setting id="SIPMaxCall" value="2" override="true"/>
<setting id="SIPSipTransportMode" value="0" override="true"/>
<setting id="ComLogSize" value="50" override="false"/>
<!-- RTP Map -->
<!-- <setting id="SIPPreferredVocoder" value="8;0;18" override="true"/> -->
<setting id="SIPDtmfMode" value="2" override="true"/>
<setting id="SIPGroup1DtmfMode" value="2" override="true"/>
<setting id="SIPUseSeplos" value="true" override="true"/>
<setting id="SIPForwardDurationNoreply" value="20" override="true"/>
<setting id="TelephonyHideIdentity" value="false" display="true" override="true"/>
<setting id="AgendaDefaultAppointments" type="TEXT" maiCategory="Application" category="Agenda" display="true" override="true" value="#" />
<!-- dialing Rules -->
<setting id="DialingRuleCountryCode" define="default" override="true"/>
<setting id="DialingRuleAreaCode" define="default" override="true"/>
<setting id="DialingRuleMinNumberLength" define="default" override="true"/>
<setting id="DialingRuleExternalPrefixExceptions" define="default" override="true"/>
<?xml version="1.0" encoding="utf-8"?>
<settings>
<setting id="HomepagePreviewMode" value="true" override="true"/>
<setting id="EnableWebappHotel" value="false" override="true"/>
<setting id="EnableWebappVoicemail" value="8000" override="true"/>
<setting id="ScreenSaverDelay" override="true" value="600" />
<setting id="ScreenSaverBrightnessOff" override="true" value="8" />
<setting id="EnableEmailPreview" override="true" value="false" />
<setting id="EnableWebappProgkeys" override="true" value="false" />
<setting id="DmWebappDeploymentMode" override="true" value="OPEN" />
<setting id="EnableWebappWakeup" override="true" value="true" />
<setting id="EnableRoutingLed" override="true" value="true" />
<setting id="EnableAgendaCalendarPreview" override="true" value="true" />
<setting id="IsHelpAvailable" override="true" value="true" />
<setting id="ScreensaverSlideshowList" override="true" value="http://dmserver/dmictouch/pictures/myScreenSaverPicture1.jpg;http://dmserver/dmictouch/pictures/myScreenSaverPicture2.jpg;http://dmserver/dmictouch/pictures/myScreenSaverPicture3.jpg;http://dmserevr/dmictouch/pictures/myScreenSaverPicture4.jpg;http://dmserevr/dmictouch/pictures/myScreenSaverPicture5.jpg" />
<setting id="ScreensaverSlideshowLocked" override="true" value="false" />
<setting id="UserBackgroundPicture" override="true" value="http://dmserver/dmictouch/pictures/myBackgroundPicture.jpg" />
<setting id="SkinsList" override="true" value="Pep's,peps-Default,false#Classic,classic-Default,true#Harmony,harmony-Default,false#GreenUp,greenup-Default,false" />
<setting id="UserPhoto" override="true" value="http://dmserver/dmictouch/pictures/grobi1.png" />
</settings>Re: Configure MyIC as Business user with OXE R
Thanks Alex,
it works with me,
it works with me,
I want to know that how can I upload these files?
DM again sir, PLEASE read documentation. Without you fully understanding the product there is nothing we can do to help you
skipper-com
Alex, would you please explain the correct setup of config server and 8082? Is it possible to use HTTP server or nor only HTTPS)? If HTTPS, how have you created CTL file and deploy it to 8082's? What URL did you use for DM configuration in 8082 (just for example)?
skipper-com
Thanks guys! No need answer more:)skipper-com wrote:Alex, would you please explain the correct setup of config server and 8082? Is it possible to use HTTP server or nor only HTTPS)? If HTTPS, how have you created CTL file and deploy it to 8082's? What URL did you use for DM configuration in 8082 (just for example)?
I've found out that HTTP is enough for all (configs, upgrades, etc). Works fine with OXE w/o any 8770, formal DMs, OT or OXO.
Hi Skipper-com,
can you give the details that how you manage 8082 without 8770 and opentouch.....
