6850 Firmware upgrade problem
Belavrin
Post by Belavrin »
i have search the hole internet and have tried everything with no result, i hope you can help me.
I want to upgrade my 6850 and also my 6850E to the 6.4.4.R01, but some of them have the 6.1.3 on it, so i have to upgrade the first to the 6.3.4 version.
But there i got a problme:
The upload of the K2os.img, Kadvrout.img,... worked fine
Now i want to upload the ku-boot.bin and kminiboot.uboot (also 6.3.4) but i am not able to transfer them, in Web View i can see this:
Starting Ftp Session...
Error:java.io.IOExeption:FTP Login faild...java.net.ConnectException: Connection refused: connect
transfer faild on kminiboot.uboot
I have also tried via DOS FTP it also didn't work.
Here is my switch config:
! Stack Manager :
! Chassis :
system name vxTarget
! Configuration:
! VLAN :
vlan 1 enable name "VLAN 1"
! VLAN SL:
! IP :
ip service all
ip interface "default" address 172.16.1.1 mask 255.255.0.0 vlan 1 ifindex 1
! IPX :
! IPMS :
! AAA :
aaa authentication ftp "local"
aaa authentication http "local"
user password-size min 4
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
! SNMP :
! RIP :
! OSPF :
! BFD-STD :
! ISIS :
! IPv6 :
! IPSec :
! IP multicast :
! IPRM :
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
! Udld :
! Netsec :
! Port Mapping :
! Link Aggregate :
! VLAN AGG:
! 802.1Q :
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
! Server load balance :
! System service :
swlog console level debug3
! SSH :
! VRRP :
! Web :
! AMAP :
! LLDP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
! ERP :
and here is the ls -r
Listing Directory /flash:
drw 1024 Jan 15 15:37 network/
drw 1024 Jan 16 10:04 working/
-rw 319 Jan 16 10:05 boot.params
-rw 64000 Jan 16 10:06 swlog1.log
drw 1024 Jan 15 11:01 switch/
-rw 64000 Jan 16 10:17 swlog2.log
drw 1024 Jan 16 09:42 certified/
-rw 11 May 5 2008 boot.slot.cfg
-rw 40 Jul 31 2009 H1584451.license.txt
-rw 20 Jan 15 11:01 installed
Listing Directory /flash/network:
drw 1024 Jan 15 15:37 ./
drw 1024 Jan 16 10:05 ../
-rw 91392 Jan 16 10:12 userTable5
-rw 33 May 5 2008 policy.cfg
-rw 404 May 5 2008 ssh_host_dsa_key
-rw 358 May 5 2008 ssh_host_dsa_key.pub
-rw 12 Jan 15 11:02 lockoutSetting
Listing Directory /flash/working:
drw 1024 Jan 16 10:04 ./
-rw 15490680 Jan 15 11:00 Kbase.img
-rw 1786112 Jan 15 10:59 K2os.img
-rw 318 Jan 16 10:04 ku-boot.bin
-rw 787 Dec 19 2006 software2.lsm
-rw 5596556 Jan 15 11:00 Keni.img
-rw 590990 Jan 15 11:00 Ksecu.img
-rw 1058 Jan 16 09:42 boot.cfg
-rw 2740122 Jan 15 10:59 Kadvrout.img
-rw 3437 Jan 15 11:00 Kencrypt.img
Listing Directory /flash/switch:
drw 1024 Jan 15 11:01 ./
-rw 105613 Oct 20 2006 certs.pem
-rw 20 Jan 16 10:05 snmp.engine
-rw 0 Oct 20 2006 pre_banner.txt
drw 1024 Jan 15 11:01 avlan/
-rw 1732 Jan 15 11:01 label.txt
-rw 944 Oct 20 2006 wv-cert.pem
-rw 981 Oct 20 2006 wv-key.pem
-rw 1732 Apr 20 2007 label.txt.bk
Listing Directory /flash/switch/avlan:
drw 1024 Jan 15 11:01 ../
-rw 445 Jan 15 11:01 topA.html
-rw 358 Jan 15 11:01 topB.html
-rw 388 Jan 15 11:01 bottomA.html
-rw 384 Jan 15 11:01 bottomB.html
-rw 2444 Jan 15 11:01 myLogo.gif
-rw 8698 Jan 15 11:01 javlan.cab
-rw 12929 Jan 15 11:01 javlan.jar
-rw 1121 Jan 15 11:01 avlanMacInstall.html
-rw 51200 Jan 15 11:01 avlaninstall.tar
-rw 12090 Jan 15 11:01 javlan.jar.sig
-rw 5327 Jan 15 11:01 javlaninstall.sit
-rw 11698 Jan 15 11:01 javlanmacosx.jar
-rw 1722 Jan 15 11:01 reconfigApple.html
Listing Directory /flash/certified:
drw 1024 Jan 16 09:42 ./
12358656 bytes free
Best regards
Alex
Belavrin
Re: 6850 Firmware upgrade problem
Post by Belavrin »
Hi@all
i haven't solved the problme but found a workaround :)
I just copied the uboot and miniboot Files via SSH to the /flash dirctory, at WinSCP i can't see a File i have transferd but with a ls -r i saw the 2 files in the /flash directory with todays date.
So i did a update uboot-miniboot and it worked
Best regards
Alex
one6f
Post by one6f »
On the old os6850 you could run into low flash issue
