i have some problems with the displaying of names and numbers in the MyIC-Client on Windows. I have changed some names in the CTI-Server and on the OXE and now i have some problems (old names are displayed and so on). When i search for names i get the right entries from the phonebook but if i dial a number (internal extension) i get wrong names. I think it has something to do with the redial-list in the client (i have attached a screenshot). How can i delete this list?
Re-Dial List
RobertBreu
Re-Dial List
Re: Re-Dial List
There is a XML file where all this info is stored. If I don't remember bad it was on the MyIC installation folder
RobertBreu
Re: Re-Dial List
thank you for the reply. The xml-file is in the app-data folder of the user when you delete it everything works. Is this a bug or can someone reproduce this behavior? My lab-system has the same software-version...
Re: Re-Dial List
It is a feature to remember last dialed numbers, but it wont synchronize with ICS when something change. I will not call it a bug...but a missing feature.
daniele.bengala
Re: Re-Dial List
Is a bug not missing feature they have all the time to implement that feature, before with 6.x ics8400 was the same, today remain, they know but do nothing to resolve.
ACSE Oxe Corporate 11.0
ACSE Oxo Rce 8.1
ACSE Oxo Rce 8.1
Re: Re-Dial List
Sure as you say and know all developers tasks... go complain with ALU if you think is a bug and never reported it is your fault. For me is a missing feature. You don't like it then open a feature request.
Sent from my XPeria Z
