EXCEL STATISTICS ARE EMPTY
jpissot
Post by jpissot »
Since this morning, my customer can't generate Excel statistisc. When he generates statistics, there is an windows error and the CCS close.
I have desinstalled CCS, delete CCS folder under ProgramData then I have reinstall the CCS software.
The CCS retrieve automatically the pabx configuration. I don't know where it finds the CCS.INI. I have looked on ProgramsFile, Programs, Program Data, User/appdata, ...., I don't find CCS.ini.
Now, when I generate statistisc, the excel file is empty. There are just the column with title.
The PC is under Win7.
Thank you for your help.
PeEs
Re: EXCEL STATISTICS ARE EMPTY
Post by PeEs »
What is the CCS version you use?
I don't it is related to CCS but to Excel. Which Excel version?
vicentesilva
Post by vicentesilva »
Hi Cavagnaro,
I need your help in solving a problem of CCS.
scenario:
PBX - OXE R11.0.1_022a
CCS - 10.01.90.01
Excel - 2010
Win 7
problem:
When prompted for the generation of statistics, reports and graphs are
shown empty.
Already uninstalled and Excel CCS but still the reports and graphs empty.
do you have any idea what might be happening?
julgeb
Post by julgeb »
The ccs.ini file is here : C:\ProgramData\Alcatel\CCSupervisor
(windows 7/2008)
If you install CCS in "windows terminal server" option, ccs.ini file is here : C:\Users\userfolder\AppData\Local\Alcatel\CCSupervisor
KIKA
Post by KIKA »
jpissot wrote:Hi,
Did you solve this problem?
I had very similar, when the Excel is opened it shows many errors and at the end shows an empty statistics. Shows the template TEMP but empty.
Is it necessary to have installed all Office 2010 suite installed? or is it enough with excel 2010?
I don't know what to do with this error
That seems to be an error with the Excel template where it has lose its Macros by some reason.
Try reinstalling CCS
Saludos
KIKA
Post by KIKA »
cavagnaro wrote:That seems to be an error with the Excel template where it has lose its Macros by some reason.
Saludos
I've reinstalled many times :(. Different versions.
Weird...maybe Av? Maybe domain policies?
KIKA
Post by KIKA »
Finally, I reinstalled Excel and it works ok.
Return to “CCD / CCS / CCIVR”
