SSID don't diffused for RAP92 in 802.11a
Also known as OmniAccess Instant AP
BELHAJ
Post by BELHAJ »
We have 2 controllers OAW-4704 and there're 2 x AP92 configurated like remote AP ( RAP)
OAW-4704 version = 6.1.2.8 ==> active Master/local
the RAPs are in bridge/always mode
When we forced the VAP profile in 802.11a , the AP has UR- flag and the SSID is not diffused
When we forced the VAP profile is configured for "all" , it works in 802.11 b/g
Is there somme issue for configuring AP92 or AP93 in remote mode because it works very well
with AP105 or AP135
Re: SSID don't diffused for RAP92 in 802.11a
for single radio ap (AP9x) you need to change in ap-system-profile the default band from g to a. than it should work.
Return to “OmniAccess Wireless Access Points”
