Hi all,
We want to develop a function that allows our server to send text message to IP Touch 8 and 9-series phones. I found that there is a "paging interface" that does the function. Does any have its documentation to share?
Thanks!
Salad
Paging interface
Re: Paging interface
"Paging interface" is a wrong way to do what you want.
If you want to send message to 8/9 series phones you'd better look for CSTA or XML solutions. Check on Enterprise Portal for certified applications for already-made solutions.
saladhon
Thanks Alex. I am interested if XML can do. Can you advise the function in XML regarding text messaging?
This is a document from ALU. It is a bit old but I don't think quite a lot has changed since then.
That's true. Now it's only CSTA left. But to get full description of CSTA you need to be an application partner.saladhon wrote:But this only serves on IP phones. How about digital phone?
