TC0599 - CS V24 Configuration cable
Here you will find the official Technical Communications from Alcatel.
If you have some to add, contact tincho.rn
Locked
This technical communication is issued to inform the field of the appropriate cable part number and
cable pin out to be used when connecting to the V.24 management port on the Enterprise Call Server
(CS).
keywords:
cs call server v24 configuration cable diagram
Locked
Return to “OFFICIAL TC's”
