OSPF Issue
spriling
OSPF Issue
Post by spriling »
I have two switches with very simples configurations. In one I have vlans 10, 11 and 250. In the other 10 and 250. I'm trying to use ospf for inter-vlan communication but it's not working. Can someone please check the configuration files and see what's wrong?
boot 52.txt
boot 77.txt
Thanks in advance.
benny
Re: OSPF Issue
Post by benny »
You wouldn't need OSPF to do simple inter-vlan routing ...
"What" is not working?
Do the two systems form OSPF adjacency? You'll need to provide more information to us for being able to help you.
Benny
