HACKING 4645
jpissot
HACKING 4645
An OXE R8.1 has been hacked. They are done a lot of internationals calls.
By studying the account tickets, we can see that they used the 4645 VM to call.
I think that they are used "Public Network Caller Callback".
Someone can explain me how they can do because I've tried to call the VM, but I dont find the menu for callback.
Thank you for your help.
- tot3nkopf
Re: HACKING 4645
4645 Classes of service --> Class --> Outcall notification
You should disable direct access to voice mail from outside also. Check also for possible access through 4645 automated attendant.
There is a technical communication regarding Voice Mail security measures that can be implemented. Look for it on ABPS.
jpissot
Re: HACKING 4645
OK.
I ve disable Outcall Notification and Callback when the customer has contacted me.
But I would like to know how the hackers do to activate callback?
- tot3nkopf
Re: HACKING 4645
Do you use menu on set feature?jpissot wrote: But I would like to know how the hackers do to activate callback?
Check also the transfer from 4645 automated attendant...(Connection COS restricted?)
Re: HACKING 4645
Using DISA is one way. Other is asking for an external extensions
Sent from my XPeria Z
gelax
Re: HACKING 4645
I think that problem is "Auto Attendant Pub Net Transfert" set to "True". This parameter is very Dangerous because permit to calling an external number from any menu of voicemail with function of helper. I had same problem !!!
Re: HACKING 4645
can you explain please
gelax
Re: HACKING 4645
When you call Voicemail,press * and 0 + prefix to access to external line + number from main menu of voicemail, with option "Auto Attendant Pub Net Transfert" you can call any external number, naturally depend from right of cos.
Voicemail use Cos 0 and Entity 0, this parameter are unchangeable.
